Wow just realized its been a while since I have given an update.
Haven't had much time of late to go work on my car with Work/School
and certain parts not arriving on time or the right parts for that matter (no one on this forum)
However I finally got a chance to go out and work on my car again.
If only for a little while I managed to get some stuff done.
Today:
Removed Fuel Pump assembly I will be replacing the Pump with a Walbro 255lph setup
Finally got the last bolt out of the Battery tray (thank you home depot)
Removed the Fan shroud from the Radiator
Sorry for the stretched images my lovely assistant was in class (with the good camera :'( )
Removed The rest of Cold start assist Assembly (Resevoir and tubing)
Temporarily took out the Cruise control in order to get to the resevoir and remove the wiring harness.
Plan for tommorow is get the clutch fan off ditch the OMP finish up the Fuel pump assembly get the turbo LIM on and start running the SS fuel lines (crosses fingers)
