3/MS3 Wiring
Slim
Okay, does anybody have a Mazda 3, perferably Mazdaspeed 3 (although they should be pretty similar I imagine) wiring diagram?
Or has anyone installed a sub and amp and know which wires run the stereo signals to the front speakers?
I pretty much know exactly how/where to do my install (practically identical to the 6) but want to make sure I tap into the proper wires in the Driver's side kick panel?
Also, anyone tap into the cig lighter at all? I want to use that for the relay and want to use the right wire there as well.
Thanks.
If you dont find it, let me know. I can take a look at work tomorrow and pull the schematic off of AllData, provided its available.
Found this on mazdas247.com...
Speakers Front
White/Black = left front +
Gray/Black = left front -
White/Red = right front +
Gray/Red = right front -
Speakers Rear
White/Purple = left rear +
Gray/White = left rear -
White = rear right +
Gray = rear right -
Power
Orange/Black = 12v constant
Orange/Black with silver dots = 12v illumination
Yellow with silver dots = 12v switched
Black/Green = Chassis ground
Slim
Nice! Thanks Jay. I had already searched m3f a fair amount but I had not poked around mazdas247. That'll do.
I tapped into the rear speaker leads behind the HU when I installed the LOC for my sub; not sure I'd want to dink around with the wiring by the kick panel. Not sure if you can get them separately, but Josh's pop-up screen came with a cool wiring harness extender for behind the HU; one of those would be even better for tapping into so you don't have to cut up your factory wiring.
Slim
Yeah a lot of people do that. Cutting into the wiring doesn't scare me though. Wire taps work beautifully and when I uninstalled from my 6 I just cut the speaker level inputs right next to the tap and taped them. No harm no foul. That way I don't have to go through the process of getting behind the HU.
if you need help let me know
Thanks for the offer. I'll let you know if I do.
