All about networking
cable internet question!
So, on a whim I decided to redo a bit of the coax routing in my house--not much, but I replaced the crusty old 4-way splitter that fed my living room and bedrooms from the main drop with a nice shiny 5-2000MHz splitter, ditched an old splitter that was being used merely as a M-M coupler inline with the cable modem, and capped off any open connections with proper terminators.
Now, it could just be a coincidence, but a month or so ago, I was getting 6000kbps down and 1.8kpbs up consistently on a couple different speed test sites at different times of day--now I'm hitting 8000-11000 down and 2000-5000 up depending on which sites I use and the time of day. Sounds good so far... but when I checked my cable modems diagnostic settings, I noticed that the bit error rate has been holding steady for several days at ~1.1-1.3%, which seems awfully high. I didn't take note of the level before the cabling tweaks, but I don't think it was that high.
Anyways, the rest of the diagnostic numbers seem good according to several broadband references: downstream SNR: 37.X dB, received signal strength: -6.3 dBmV (up from 11-12 before I removed a splitter from the line), output power level: 47-48 dB. I haven't found any direct references to what the bit error rate "should" be, but I've seen several indirect mentions that make it seem like mine is orders of magnitude too high.
Suggestions?
Funny thing is you can have too much signal going to your modem. But I have read your post three times now and fail to see you ask a question othe then "Suggestions?". But with every split you make in your cable be it going to a tv or going to nothing you split the signal. So taking out a split that is unneeded will help your signal. Even an inline extention will affect your signal. So that is all i know about coax cable short of it sucks to run.
On a side note. I just purchased a bendable drill for fishing cable. I used it on two projects so far and love it. It was a bit spendy (around $50) so if anyone would like to use it or if anyone needs help just post it up.
Sorry if I was unclear... my question was about what to make of the high bit error rate, and what might be causing it, or what I can do about it--given that the rest of the parameters I can measure seem right in spec.
