So, it's pretty common knowledge that the MSP runs pretty hot, partly due to the fact that the radiator is a bit undersized in order to accomodate for the SMIC.
One thing I was considering to help account for that is running a much lower mixture of coolant/water during the summer (in addition to using Redline water wetter). Since antifreeze has a lower heat capacity than water, the less you run in your cooling system, the more effective it is at getting rid of heat. Numbers I have found indicate that a 50% antifreeze solution will carry 15-20% less heat than pure distilled water.
The only downside is that I'd have to drain and refill the coolant system in the fall to prevent freezing. Which, except for the cost of the coolant is not a big deal.
I was just curious if anyone around here does that, or if anyone has any thoughts or suggestions?
