Engine Controls - Engine No Start Condition
TSB: 01-018/07
2004-2006 MAZDA3 - NO START DUE TO FROZEN MAIN RELAY
NOTE: This bulletin replaces 01-007/06. Please update your records accordingly.
BULLETIN NOTE This bulletin supersedes the previous bulletin 01-007/06 issued on 03/15/06. The APPLICABLE MODEL(S)/VINS has been revised.
2004-2006 Mazda3 vehicles with VINs lower than JM1 BK**** ** 485606 (produced before February 1, 2006)
In extremely cold weather below -22°F (-30°C), some vehicles may experience a no-start condition. The contact point of the main relay may have frozen after short distance driving in extremely cold weather. Due to the design, moisture can enter the inside of the relay, allowing the contact point to freeze. As a countermeasure for Mazda3 vehicles, a mass production change has occurred with the following
^ For all Mazda3 vehicles (FED/CA/CAN) a breathing hole has been added to the main relay, and the capacity of relay coil has been increased.
^ For FED and CAN spec Mazda3 vehicles, the PCM logic of the main relay electric current control has been changed. After the ignition is turned off, a small, regulated amount of electric current will continue to run through the relay for 10-20 minutes.
2. For all vehicles (FED, CA, and CAN), replace the main relay with a modified one.
3. For FED and CAN spec vehicles, reprogram the PCM.
PCM REPROGRAMMING
2. Using IDS 47.5 or later software, reprogram the PCM to the latest calibration (refer to Calibration Information table) by following the Module Reprogramming procedure.
NOTE: ^ Always update the IDS tool first, then follow on-screen instructions to download the needed calibration file for PCM reprogramming.
^ IDS shows the calibration part numbers after programming the PCM.
^ Please be aware that PCM calibration part numbers and file names listed in any Service Bulletin may change due to future releases of IDS software, and additional revisions made to those calibrations for service related concerns.
^ When reprogramming a PCM, IDS will always display the latest calibration P/N available for that vehicle. If any calibration has been revised/updated to contain new information for a new service concern/issue, it will also contain all previously released calibrations.
3. After performing the PCM reprogramming procedure, verify the repair by starting the engine and making sure there are no MIL illumination or abnormal warning lights present.
^ After PCM reprogramming, it is no longer necessary to road test the vehicle to relearn KAM (Keep Alive Memory).
4. Fill out an Authorized Modifications label (P/N 9999-95-AMDC-97) with the new PCM calibration information, your dealer code, and today's date.
5. Place the Authorized Modifications label on the A pillar below the tear tag in the driver door jamb.
WARRANTY INFORMATION
NOTE: ^ This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
