TSB: 01-039/07
2006-2007 MAZDA3 - ENGINE IDLE DIP WHEN A/C CYCLES ON
2006-2007 Mazda3 vehicles (CA spec only)
with VINs lower than JM1BK**** ** 774383 (produced before May 31, 2007)
2006-2007 Mazda3 vehicles (2.0L and A/T except CA spec)
with VINs lower than JM1BK**** ** 791118 (produced before July 1, 2007)
Some vehicles may experience an engine idle drop when the A/C cycles on and off (normal operation) at a stop. Body vibration may also be felt.
The PCM software has been revised to eliminate this concern. Customers having this concern should have their vehicle repaired using the following repair procedure.
When reprogramming the PCM of the 2007 Mazda3 with 2.3L (L3) engine and automatic transmission, the TCM also needs to be reprogrammed.
2. Using IDS 50.4 or later software, reprogram the PCM to the latest calibration (refer to Calibration Information table) by following the Module Reprogramming procedure.
NOTE: ^ Always update the IDS tool first, then follow on-screen instructions to download the needed calibration file for PCM reprogramming.
^ IDS shows the calibration part numbers after programming the PCM.
^ Please be aware that PCM calibration part numbers and file names listed in any Service Bulletin may change due to future releases of IDS software, and additional revisions made to those calibrations for service related concerns.
^ When reprogramming a PCM, IDS will always display the latest calibration P/N available for that vehicle. If any calibration has been revised/updated to contain new information for a new service concern/issue, it will also contain all previously released calibrations.
3. After performing the PCM reprogramming procedure, verify the repair by starting the engine and making sure there are no MIL illumination or abnormal warning lights present.
^ After PCM reprogramming, it is no longer necessary to road test the vehicle to relearn KAM (Keep Alive Memory).
4. Fill out an Authorized Modifications label (P/N 9999-95-AMDC-97) with the new PCM calibration information, your dealer code, and todays date.
5. Place the Authorized Modifications label on the A pillar below the tear tag in the driver door jamb.
WARRANTY INFORMATION
NOTE: ^ This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
