TSB: 01-035/07
MULTI-MODEL - ENGINE VIBRATION/KNOCKING NOISE/NO. 3 ENGINE MOUNT RUBBER BROKEN
This bulletin replaces 01-021/05. Please update your records accordingly.
BULLETIN NOTE This bulletin supersedes the previous bulletin 01-021/05 issued on 07/13/05. The DESCRIPTION, APPLICABLE MODEL(S)/VINS, and PART(S) INFORMATION have been revised.
2004-2006 Mazda3 with VINs lower than JM1 BK**** ** 533507
(Produced before May 8, 2006)
2006 Mazda5 with VINs lower than JM1 CR**** ** 127354
Some vehicles may exhibit a knocking noise from the engine compartment when starting/shutting off the engine or may experience excessive engine vibration at idle. A likely cause of this is a broken No. 3 engine mount. This symptom could be observed under any condition such as accelerating or idling with the engine hot or cold.
The No. 3 engine mount rubber has been modified to address this concern.
1. Verify concern.
2. Replace the No. 3 engine mount rubber with a modified part. Refer to Workshop Manual section 01-10.
3. Verify repair.
WARRANTY INFORMATION
NOTE: ^ This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
1. Verify concern.
3. Verify repair.
