I have wheels (stock 17")... I would just need time to cherry pick them (keep the best 4, and get the tires swapped onto them)... they non-picked ones are going to not going to be all that pretty, and one will be dented. A tire may also be needed for one of them as it's dead to the point of not holding air.thanks, the only major thing needed done is swapping the wheels with another set(which i still need to find). i already have another set of tails lined up, need to pull some interior electronics, and see if any of my HID kits are salvageable.
wait, so do you have 2 sets of stock rims? i'm kinda confused. and if you only have 3 wheels with good tires, i can always use my spare. i'll let you know for sure after the adjuster looks at the car.I have wheels (stock 17")... I would just need time to cherry pick them (keep the best 4, and get the tires swapped onto them)... they non-picked ones are going to not going to be all that pretty, and one will be dented. A tire may also be needed for one of them as it's dead to the point of not holding air.
What year is yours again, and does it have side airbags? I wonder if your right shoulder isn't due to the seat frame issue where the force of the crash tore the foam through the seat support and your shoulder came down on the metal frame.
I would also be interested in swapping the jack. I broke mine.
