I'm pretty much looking to refurbish them as much as possible, though the glass is fine so I'll be reusing it. Here's my plan at the moment:
-Remove sashes from frame, remove glass from sashes
-Strip old paint, sand, and prime sashes
-Replace and reglaze glass
-Paint sashes
-Sand and prime window jambs
-Replace separating bead if necessary
-Replace counterweight cords if necessary, lubricate pulleys
-Install new weatherstripping (probably use vinyl v-shaped stuff)
Like I said, I've read up on the general procedures, and I think I've got all the materials (oil-based primer, oil-based putty, glazier's points, etc), but if you've got any pointers, I'm all ears.
