Colin wins this thread.
I am almost certain it is install error. LOL.This sounds like an install error.(sorry) I think if we can take a look at Porky's we will be able to figure it out.
Also did your forge come with a new hose clamp for the large dump pipe?
Not telling your that is the issue but it will fix the small issue you have.
Also The shims go on the top side of the valve. The side that doesn't move to dump pressure. Was there a lot of white grease on the internals of the valve? if not then you could have a sticky mess in there. That can get fixed by doing a valve service and regrease the seals.
Although my inlet is not silicone, the connecting pieces are perhaps it just resonates more now?Mine sounds like a groundhog bark. Others are having the same sound after installing the Cobb inlet. Different BPV are being used and still have the same sound. It's not surge but seems to be the released pressure hitting the silicone inlet. I'm not for sure what is happening but people running the metal inlets have not report this sound so I believe it has to do with the silicone inlets.
Well, the same thing can happen when the throttle plate slams shut and the turbo is still spooled and trying to cram air into the motor. It's obviously a much more instantaneous and short-lived phenomenon than the truly dangerous type of surge you described (and Luke illustrated in his first vid), but the phenomenon is the same.
The type of surge you're describing kills turbos. The type of surge that results from an insufficient bypass/dump setup can "merely" increase wear.
He failed to post the link though.My guess is that the cap o-ring has failed and the upper portion of the valve can't hold enough vacuum to keep the valve open. This is causing the piston to open and close rapidly and making the "turkey" sound.
Perform the "pent-test" in this PDF and let me know what happens.
