Okay, so I installed my catless midpipe this weekend, and it went relatively smooth, save for a medium-sized exhaust leak where it joins up to the crappy catback that was installed on the car when I bought it. The flanges don't line up quite exactly enough, so even with a new OEM gasket, and the bolts (it's a 2 bolt flange) tightened down as much as I can, there's still a pretty good puffing of air coming out of the bottom side of the joint. I even tossed in a couple of large washers to try and distribute the bolts' clamping power over as much of the flange surface as possible, hoping it would pull the bottom edge shut tighter.
Anybody know of a good way to seal up a leak like that? I mean, this thing is going to be loud enough as it is without the exhaust leak... lol
Maybe I'll just have an exhaust shop weld up the joint?
