concealer404
Skanky Escorts LLC
As most of you know... i currently own a 1992 Celica GT hatch with a fairly worked suspension.
I also have an ST205 Celica GT4 (94-99) transmission and transfer case.
And a 3sgte with spun bearings that i was/still am going to make a stroker motor out of. (3sgte is alphabet soup for Toyota's answer to the Mitsu 4g63T)
I will need a Solara V6 trans to make that setup drop in and work with my car.
I was just offered this for $300.
Don't get too excited. It's a shell at this point. Has all glass, body is straight and rust free. Is definitely missing entire suspension assembly. Trying to figure out what it has in terms of interior/wiring. Does not have hood. (Doesn't matter, i hate that hood anyways)
It will cost me $250 to get it home, but it is a REAL AllTrac.
What i was hoping was that all my suspension/hubs would swap from my GT over to the AllTrac, and i'd strip the GT, crush it, and get to work on alltrac using the ST205 drivetrain stuff i already have.
Problem: Only the front stuff swaps over.
I would definitely be able to use the custom bracing i made for the GT on the AllTrac. Everything that will work from GT on AllTrac:
1) Front suspension (all of it. Currently has Cusco underbody brace, megan racing track-spec coilovers, whiteline sway bar)
2) Hood
3) Hatch
4) Would keep my GTS front fenders as backup
5) Carlos Sainz bumper (though i think the AllTrac already has one)
6) Any and all interior stuff i happen to have left.
7) Engine and trans mounts
But really... swapping over just the front coilovers doesn't make sense. So at the least, i'd be sourcing coilovers, rear subframe, rear diff, driveshaft, all rear control arms, rear hubs, rear brakes.
Pros for GT: Lighter, already have it, i know the history of the car, already together.
Cons for GT: FWD, doesn't have rear widebody flares
Pros for AllTrac: It's an AllTrac. Pretty much starting from body-in-white. Already modified to fit 305/30-18 tires.
Cons for AllTrac: Heavier, looks like a bit of work to even get it to rolling chassis form at this point.
I'm not sure what to do at this point. Bear in mind that i will not just ADD the AllTrac to the stable. If i get AllTrac, the GT gets stripped and crushed. The GT is the immediate "easy button," the AllTrac is the eventual "awesome button," but i also think for the work to get it going, i could easily convert the GT to AWD, though i'd still have to sort out figuring out how to get lots of tire in the back. GT will always be lighter.
I'm wondering if it's just the above picture that's making it hard to decide.
Input? Double facepalms are ok (i'm looking at you, Picklz), just please give some input either way. Also: Ignore my other projects. This is purely a choice between the two cars.
Here's the GT:
2) Hood
3) Hatch
Here's the GT:
