Pulstar plugs GB?
sorry to tell you E but plugs are not that big of a deal. Even drag cars that make over 1000 hp use plain old NGK plugs.
Yeah, I'd take a pass on these, even if they did get all the way to the lowest pricing tier. They talk a lot of fancy tech, but in the end it all comes off pretty gimmicky.
although a dyno would definatly show more info than needed. i just did want to spend that dough on that. overall i definatly think it improved IDLE QUALITY, ACCELARATION, ACCELARATION SMOOTHNESS, and overall helped slightly in drivability.
WoW so you will spend 14-24 a plug but not 100 for one run on the dyno to see if they help HHMMMMMMM odd.
Any gains from a spark plug are from either:
1) Your ignition system was not operating correctly to begin with
2) Small gains from chages in air temp, ign timing, or some other outside factor not related to the plugs themselves.
Dont waste your money...
