why you shouldn't buy cheap lug nuts...
LASERBLUE135
Active Member
So I'm swapping on my winter rims and I broke a "tuner" lug nut in half. One half on the wheel and the other half lodged in my tire iron. @$@!#$%$@! Now I have to buy new lug nuts...work on fixing my tire iron...and pay someone to get that lug off my rim.
Dude, just find a 6-point socket that's just slightly smaller than the diameter of the nut, pound that bitch on there, then attach socket wrench and remove.
Or, chisel that shit off. Go parallel with the stud, one on either side of the nut and it'll split in half lengthwise. If it's cheap enough aluminum to break from just trying to take it off, an old rusty chisel ought to be able to cut through it.
Take a can of air, flip it so that it does the cold thing. Freeze the shit out of it and hit it with a chisel and hammer. Done right, that thing should shatter w/o fucking up your wheel stuf.
Just be careful not to fuck up the threads on the stud. Though, at least you'd have saved yourself from having the finish on your wheels ruined by a torch.
LASERBLUE135
Active Member
I'm going chisel and drill combo. Slow, methodical and patient. I Googled it (imagine that works sometimes) and ran into a few other cases and thats how they got it.
One thing to keep in mind, if you are going to use a drill, keep a spray bottle of water handy. While it's not going to fuse to the stud itself, cleaning aluminum out of threads because you got it too hot with a drill and melted it is bad. That being said, I think you have the right idea. I'd notch ith with a thin drill bit, and hit it on the notch with a chisel.... should crack right in two with that. And NEVER BUY ALUMINUM LUG NUTS AGAIN.
LASERBLUE135
Active Member
AAAAAAAAAAAAAAARRRRRRRRRRRRRRHHHHHHHHHHH, I didn't buy the lug nuts!!!!!!!!!!!!
W
WhiteSpy9
ridiculous.......
well done getting getting it off though.
