All thanks to CP-e. I'll try and summarize most of what I found:
'Socks' is a friend of mine on MazdaSpeedForums.org. He has a fully built bottom end with a stock head and a GT3071. Used to run nitrous and made decent numbers. Tried everything he could, like many other big power hunters, but always hit the mysterious ceiling.
Numerous tuners have taken a crack at breaking this wall and it's finally been done. I'm happy to see CP-e has come up with the magical solution - a simple ECU flash. Now, if you have a turbo capable of 450whp, and the air and fuel to support it - your car will now hit 450whp.
Let's see if I can break down the numbers:
Sean's dyno run (on a dynojet) made him 433whp/440wtq. on the bottle:
Arias Pistons (8.8:1)
Pauter Rods
ARP studware
GT3071r @ 20psi with 3" vband exit, T3 flange, .82a/r
Cobb AP
Cobb FMIC
3" TBE
DNP Mani w/ Tial 44mm Gate
Zex 125hp Wet Kit
3.5 bar MAP sensor
Dual 255 fuel pumps
63mm throttle body
Ported intake mani w/ VCTS delete
Yada yada...
He later took off the nitrous for various reasons and dyno'd at Cobb's dynojet and made 355whp on 21psi (can't remember if that was with meth).
And now, he's added the CP-e 'magic' flash and made an unheard of 428whp on only 19psi (also on a dynojet)! They've gained 73whp while using 2 lbs of LESS boost! Sean's car also had an injector seal pop off mid-run so there was more left in it. He was also running on a stock head and intake manifold as he had to pass emissions (VCTS in place again). They're saying 450-470whp would've been seen. This is it ladies and gentlemen. The beginnings of true power are here.
Here's his mustang dyno run. Like I said, the injector seal popped off on the dynojet so I didn't see any graphs.
Note: CP-e has said their Mustang dyno's reading about 17% LESS compared to a dynojet.
Sean's car was on a mustang dyno in this blog: http://cp-e.com/blog/
Their forum rep said he went to a dynojet 45 minutes after those runs were posted and made the 428whp. His old set up on a mustang made 290/318 and now with the flash he made 394/400! These new numbers are without meth, and on 93 octane, and most importantly DIRECT INJECTION! No auxiliary fueling here.
For more information:
The official release: http://cp-e.com/blog/
The discussion: http://www.mazdaspeedforums.org/forum/f330/big-power-finally-here-46183/
Please share your thoughts, this is absolutely HUGE news for the community.
Pauter Rods
ARP studware
Cobb AP
Cobb FMIC
3" TBE
Zex 125hp Wet Kit
3.5 bar MAP sensor
Dual 255 fuel pumps
63mm throttle body
Yada yada...
