Alright I'm moving forward with this sumbitch, I increased the quantity of a number of items as I wanted extras if I messed something up or got a bad item or two, so that inflated the Price a bit, but here's what I bought:
From Futurlec.com
Part No. Description Qty Price Each Total Price
74HC138 74HC138 - 3 to 8 Decoder/Demultiplexer 2 $0.35 $0.70
74HC574 74HC574 - Octal D-type F/F Edge-Trigg. Tri-State 9 $0.60 $5.40
C010U16E 10uF 16V Radial Electrolytic Capacitor 6 $0.05 $0.30
C022PC 22pF 50V Ceramic Capacitors 5 $0.05 $0.25
CRY14.7456 14.7456MHz Crystal 1 $0.75 $0.75
EXPBRDLGPHEN Experimenters Board Large - Phenolic 3 $2.90 $8.70
FHEADS4 4 Pin .100 Straight Female Single Headers 1 $0.80 $0.80
GRCABLE10 Grey Ribbon Cable - 10 core 2 $0.40 $0.80
GRCABLE16 Grey Ribbon Cable - 16 core 8 $0.45 $3.60
HDCONNS8 8 Pin .100 Header Connector 9 $0.18 $1.62
HDPINF Female Pin for Header Connector 10 $0.60 $6.00
HDSHCB Shorting Block Closed Black 2 $0.15 $0.30
HEADRAS8 8 Pin .100 Right Angle Headers 1 $0.25 $0.25
HEADS2 2 Pin .100 Straight Male Headers 1 $0.70 $0.70
HEADS8 8 Pin .100 Straight Male Headers 2 $0.70 $1.40
ICS16 16 Pin IC Socket 3 $0.07 $0.21
ICS20 20 Pin IC Socket 9 $0.09 $0.81
ICS40 40 pin IC Socket 2 $0.15 $0.30
IDCC10 10 Contact IDC Socket Connector 1 $0.25 $0.25
IDCC16 16 Contact IDC Socket Connector 2 $0.25 $0.50
IDCMH10 10 Pin Shrouded Male Headers 1 $0.25 $0.25
IDCMH16 16 Pin Shrouded Male Headers 2 $0.25 $0.50
MAX232 MAX232 Dual RS232 receiver/transmitter 2 $1.50 $3.00
MCCABLE16 Multicolor Ribbon Cable - 16 Core 2 $0.85 $1.70
MPOLHDR2 2 Pin Male Polarized Header 2 $0.10 $0.20
PCBT2 2 Term. PCB 5mm Terminal Block 1 $0.40 $0.40
PCON2 "2 Pin .155"" Pins for Connectors" 2 $0.10 $0.20
PLHDPIN Crimp Pin for Header Connector 1 $0.60 $0.60
RN100R 100ohm 9 Resistor Network (10 pins) 10 $0.25 $2.50
RN1K 1kohm 9 Resistor Network (10pins) 10 $0.25 $2.50
Subtotal $45.49
Shipping $6.00
Total $51.49
From Mouser.com
Select
Product Detail
Customer Part #
Order Qty.
Price
(USD)
Ext.
(USD)
Status Date Invoice #
Mouser #: 107-LP12-7-EV
Mfr. #: 107-LP12-7-EV
Desc.: Pushbutton Switches ILLUM 12MM GRN
1 $2.79 $2.79
1 Pending Pending -
Mouser #: 10KB012
Mfr. #: 10KB012
Desc.: Pushbutton Switches LT BU BDY RND BK CAP
1 $1.35 $1.35
1 Pending Pending -
Mouser #: 10KB011
Mfr. #: 10KB011
Desc.: Pushbutton Switches LT BU BDY RND RD CAP
1 $1.35 $1.35
1 Pending Pending -
Mouser #: 279-CFR100J100R
Mfr. #: CFR100J100R
Desc.: Carbon Film Resistors - Through Hole 100Ohm 1W 500PPM
70 $0.05 $3.50
70 Pending Pending -
Mouser #: 647-UVR1C101MDD1TD
Mfr. #: UVR1C101MDD1TD
Desc.: Aluminum Electrolytic Capacitors - Leaded 16volts 100uF
3 $0.05 $0.15
3 Pending Pending -
Mouser #: 647-UHM1C102MPD3TD
Mfr. #: UHM1C102MPD3TD
Desc.: Aluminum Electrolytic Capacitors - Leaded 1000uF 16V 105c
5 $0.11 $0.55
5 Pending Pending -
Mouser #: 594-K104K15X7RF5TH5
Mfr. #: K104K15X7RF5TH5
Desc.: Multilayer Ceramic Capacitors (MLCC) - Leaded 0.1uF 50volts 10% X7R 5mm LS
18 $0.06 $1.08
18 Pending Pending -
Mouser #: 279-FRN50J1K0/S
Mfr. #: FRN50J1K0/S
Desc.: Metal Film Resistors - Through Hole 1 KOhm 1/2W 350PPM
20 $0.04 $0.80
20 Pending Pending -
Mouser #: 512-PN2222TA
Mfr. #: PN2222TA
Desc.: Bipolar Small Signal NPN Transistor General Purpose
18 $0.06 $1.08
Mouser #: 556-ATMEGA32A-PU
Mfr. #: ATMEGA32A-PU
Desc.: Microcontrollers (MCU) 32KB In-system Flash 2.7V - 5.5V
2 $5.36 $10.72
2 Pending Pending
total of $23.37
And a USB programmer for $27 shipped
http://evilmadscience.com/productsmenu/tinykitlist/106-usbtiny
So right around $100 total with shipping, I just made an offer for 1000 green LED's on Ebay for $23 so we'll see if that get's accepted. I probably have $15-20 worth of 'extra' parts that could go towards a second cube, depending on how my first one turns out I may build a blue one next
Note I already had some items like Solder, Soldering Iron, Kynar wire, etc so I didn't have to buy any of that. And I have spare wood to make a base and such.
I decided to use a spare PC power supply for now, if the cube turns out really well I'll probably build or buy something that looks nice or can be hidden in the base
I'll try and keep this updated with my progress
