dasmikechen
Hello, I am a relatively new 2009 Ms3 owner. Metro Gray, Minneapolis area.
Things I have done thus far:
MS CAI, what a wonderful sound it makes.
Fog light bulb replacement to 'match' HIDs, bought the 7000k color temp matching lights from Street Scenes Tint in Brooklyn Park. Nice match!
Threw in my kenwood 800W and 2 12"s from last car, no replacement stereo so quality is so-so.
Other things I am planning:
Cp-e Triple gauge pod containing:
Water Temp
Oil Press
Voltmeter (due to system install)
NEW Cp-e Single gauge pod (with vent ports and hole for wires) containing:
Boost
Can you guys advise me as to where to tap for the water temp? I was going to get the radiator upper hose adapter from ProSport but I've heard that under certain circumstances, this hose will not be routing any coolant at all. Is there a place to tap on the block? Thanks in advance.
Also, I have read about 3 different places to tap the vacuum line for boost. The tube leading from the BPV/BOV, the tube leading to the MAP, and the tube leading to the Fuel Pressure Regulator. Which do you guys recommend and are they readily available? Thanks again in advance.
If this is slightly out of place in the forums, I apologize; I am new. PMs are welcomed as well. Thanks! Nice to meet you guys, hope someday to take a spin with you and check out your rides!
Water Temp
Oil Press
Boost
